メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Surface Pro 4の後継モデルとして2017年6月発売。別名Microsoft Surface Pro 12.3インチとも呼ばれます。モデル番号はFJT-00001。
Replaced Battery, this is what I got..
Was wondering what I broke here? I was very careful and it seemed to be okay when I replaced the battery and reassembled it.
The screen is not cracked, but I was wondering if it was a connection issue. However, why would just a strip display like this?
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I am sorry to say this James, and others can chime in here if they disagree, but I'm pretty sure that screen is dead.
There's a chance it is a connection issue. Did you try reseating the cables? But if not, it is likely a separation issue where the screen was pulled apart and the layers through which the data connection flows were separated at some point.
It is not exactly your fault, Microsoft has made these things as hard to service as possible (they earned the lowest possible repairability score for a reason), and no matter how careful you are screen issues have been known to happen on Surface devices.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
James Buchanan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 273
