Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
このアンサーは役に立ちましたか?
None of them helped
過去 24時間: 1
過去 7 日: 5
過去 30 日: 49
今までの合計 570
4 件のコメント
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
BurtBen さんによる 共有
No it's actually beeping like a car's blinker
Jackson King さんによる 共有
Could you possibly record it and add it to the post?
Not sure how?:
iFixitでの質問に画像を追加する方法
BurtBen さんによる 共有
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
JnCA さんによる 共有
