メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
10.1インチGalaxy Tabタブレットの第3世代モデル。
LCD screen Ribbon Connector
Hi,
So i have a random question. I had a broken samsung tab 3 and iv taken it apart for a project. I wanted to know is there a way to change the Ribbon Connector to a 40pin? Or is there away of taking the gray tap (not sure whats its called) to put a 40pin ribben cable to it and complete void the LCD board.
Update (06/23/23)
画像
Hi sorry about that.
Im wating to reuse it for a rasberry pi by installing a Display Monitor Driver Board
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
@learning201 the board we are looking at is the LCD driver board? Connected to your display panel? What is the exact model number for your tablet (GT-P5200?)
By using the display connector schematic, could you not determine which pin does what and move on from there.
さんによる
コメントを追加
1 件の回答
ベストアンサー
if you add photos and the reason why you want to change to 40 pin then it will give people a better understanding of what you are trying to do
Update 06/23/23
@learning201 you would need to find out what each pin is for, some will be ground, others could be for single rails or you could have 2-3 pins connected to 1 rail
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Learning201 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 405
