メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年11月にiPad Proシリーズの一員として発売。モデル番号A1980。
Screen replacment adhesive built in!
Hello everyone
Am about to fix my broken ipad ( screen and battery ). But i notice in the parts descrption that the screen ifixit provide it have adhesive already.
So. Is it true the screen have adhesive already so i don’t need to buy one or not!!?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I'm having a hard time understanding your question, but I'll answer as best as I can.
If the screen isn't broken or damaged, you can replace the adhesive yourself. If the screen is broken, it would be recommended to replace the screen, which the new one comes with adhesive preinstalled. So you don't need to worry about buying it.
Make sure you remove the old adhesive and residue from the frame to ensure the new screen adheres properly. I personally use acetone, a razor blade, and q-tips to clean the frame off old residue. I'll also make sure the frame is free of bends or dents, especially in the corners. You can file those down, but get a good protective case for the device. Once the new screen is installed on the frame, I'll heat up the edges of the frame around the display to warm up the adhesive and place some weights or clamps around the edges to make sure the screen sticks. I wouldn't use more than a total of 5 pounds (lbs) of weight on the screen and let the frame cool completely.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you Jesse.
You Answered my question.
I just want to be sure that the new screen it have adhesive preinstall already.
Beacuse i remember when i read the screen description i don't notice anything about the preinstall adhesive!!
And yeah. The screen is broken in two places.
さんによる
@yosuf glad I could help. Good luck fixing!
さんによる
コメントを追加
回答を追加する
Yosuf Harmoush さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 413
