メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年3月に発表・発売された、iPad Pro 12.9インチ第4世代の修理と解体情報。モデル番号はA2229。
Ipad 4th Gen ISSUE
I have a ipad 4th gen and when using the screenflashes purple quickly and restarts. this is happening all the time now and cat really use it. any ideas how to fix without taking it to apple for an extremly high fix price and no i dont have a warranty.
画像
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
You may not have Apple Care+ but if the device is not damaged, you have a manufacturer’s warranty for a year from original purchase date. Since the 10th gen didn’t even come out until October of last year, you should still be well within this. You can check at Apple’s Coverage Checker with your serial number.
(I just noticed your post says 4th gen, in which case, no you would be well out of warranty).
Otherwise, for some ideas of what might be causing the issue, I would check to see if you have any panic logs that were generated from the crashes.
In your Settings, navigate to Privacy > Analytics & Improvements > Analytics Data. Skim through this list for any files with the name panic.full in the title. If you find any with recent dates, add a screenshot, or copy the first page or so of the log’s text into your question.
UPDATE 06/21/2023 - Based on the panic you gave, I found this post in another forum, which seems to point to a similar issue occurring in some versions of iOS 15. It’s possible this is a software issue. The panic is actually pretty vague–“Kernel data abort.”
But I suspect in your case it may be hardware related. It’s hard to know for sure. This particular panic also calls out fitcored as the panicked task. Which relates to fitness/health functions. There is also specific mention of Apple USB Audio Device Driver. Which may not mean much depending on the underlying cause. But could be relevant if there are other panics which mention the same things.
Digging into some of my resources, I found mentions of CPU or CPU power. Which could make sense based on these symptoms. I am always skeptical of these sort of bulk lists on unvetted solutions with no explanation or reasoning. But it’s better than nothing. On 12.9” models I always worry about bend, which can cause board issues.
I would try a software restore first. Or DFU even honestly. I would normally put in links fo directions on those, but I have already been nursing this answer too long and I want to get it posted. Seeing more panics might also help, in the case that they aren’t all the same.
このアンサーは役に立ちましたか?
スコア 2
11 件のコメント:
there is one that has panic full in there.
さんによる
not sure how to add pic of ot tho?
さんによる
@choose35196 go to options and edit, above where you write there is a toolbar over next the right there is a box shape image beside a curve arrow, thats for images
さんによる
Ok, it done now.
さんによる
Can you see the picture i uploaded.
さんによる
6件以上のコメントを表示
コメントを追加
画像の内容を見る:
画像
画像
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can someone look at this and help? iPad Pro 12.9 (4th Gen). Apps keep crashing and iPad gets stuck in a reboot loop. I have to use my Macbook to either restore the iPad to factory settings, or update its software.
さんによる
コメントを追加
回答を追加する
choose さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 16
今までの合計 573
