bypass lock screen on tablet
How do I bypass lock screen
Hello! Starting with the tablet turned off, if you hold the power and volume up buttons for a while it should load into the recovery menu! From here you should have the option to factory reset it. That's most likely your best option, although you will use all the data currently on it.
このアンサーは役に立ちましたか?
Hi @ezzgen,
What about FRP lock due to reset?
Don't remember the pin most likely don't remember the account either
Cheers
That is true, atleast you can recover the username/password for a google account!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 720
