メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo Yoga 920-13IKBは、画面を反転させることでノートパソコンとタブレットの両方の機能を持つ2in1ノートパソコンです。
Computer Will not turn on or charge
Out of the blue, my laptop died. It won't charge. Charge light won't come on and it won't power up and turn on when the power button is pressed. I don't get it, as I hardly ever used this computer. I've heard the computer has some firmware issues reading online. But I tried all the recommended hard reset options, including detaching the battery cable. But no dice. Is my mother board dead? If so, how can I make sure? Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Hi @hatelenovoyoga,
Have you tried using a different, known working compatible charger to see if the laptop started to charge when it is connected, you didn't say?
Try using a strong light and a magnifying glass to visually inspect the USB-C charge port pin connectors (where the charger plugs in) to make sure that they're all there and not that some may be bent, broken or even missing.
Here's a link that describes the USB-C pin functions that may help.
If there are missing, bent pins etc then the charge port (supplier example only) will have to be replaced. You will need smd soldering skills and tools to do the repair. Here's the hardware maintenance manual that may also help as the systemboard will have to be removed so that the port can be replaced. The manual details how to do this.
If the charge port appears to be OK, here's a link to the schematic for the systemboard (if your model is an NM-B291 REV:1.0 that is). Go to p.41 to view the connections for the charge port so that you can check if power is getting through the port OK and how far into the board it gets etc.
Hopefully a start.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here are some quick fixes for this issue
  1. Try changing your laptop charger
# If charging point is blinking and caps lock is blinking then you need to repair the motherboard of the laptop,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
HateLenovoYoga さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 30
今までの合計 1,125
