How can I repair display cable?
connecter between backlight - screen has been disconnected.. how can it fixed?
buy connecter or soldering?
Now that your screen is off, order the display cable kit that has matches your iPad. Remove the small screws that hold a small shield that hold the display cables in place on the upper side of your screen. Once the shield, on the display has been removed, you can now attach the replacement cables to both the screen and to the inside connectors that are inside the body of the iPad,
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 249
could you upload better pictures?
Jesse Hooton さんによる
