メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
S-10ピックアップトラックをベースにしたミッドサイズSUV、初代Chevy S-10(4WDモデルT-10)Blazerの修理ガイドとサポート情報。GMC Jimmyと密接な関係にあるモデル。
Need help with my lights
My passenger headlight doesn't work on dim and the passenger tail light is stuck on bright
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @debbieholliday,
What is the year model of the vehicle?
さんによる
コメントを追加
1 件の回答
Assuming you've tested the switch and tested the lights separately, and the wiring is okay (problem doesn't come & go when you move any part of the wiring loom around). Then it's likely a Body Control Module issue (common problem) on this one, and quite a few others too. The quickest way is to buy a change-over unit from a parts supplier (repaired, tested and under a good warranty - & cheap enough). I wouldn't recommend second-hand, as these are a common problem for years. If you want to repair your own, you'll need a de-solder station & soldering iron with adjustable temperature. Re-work any dry joints you can find (especially on connectors and relays) and clean out the PCB relays (difficult to get exact replacements for). Use a 5mm strip cut from thin card and pinch it gently between the relay contacts while drawing it through until you can't see a black carbon trace on the card any longer. I've personally fixed hundreds of these and many more like them. If you need help repairing, post photos of both sides of the BCM PCB.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Debbie holliday さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 403
