メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Galaxy SIIIの低価格版スマートフォン。Samsung I8190 Galaxy S3 miniやSamsung Galaxy S IIIなどとも呼ばれます。 NFC対応のSamsung I8190N Galaxy S III miniも存在します。モデル番号GT-i8190で識別可能です。
Screen flickers after battery replacement
Hi, I my GS3 mini’s battery was on it’s last leg, so I bought a new battery for it. However, it appears that the third party battery I bought was rated for 1350mAh, while the original was 1500mAh. When I run it on the weak original, no flickering. On the new one, flickering. How do I fix this without buying a new phone or yet another battery replacement? (I bought a Samsung Original)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
@stechkid just based on this "on the weak original, no flickering. On the new one, flickering." replace the battery once more. Get it from a different supplier. This appears to be a power issue due to a "bad" battery. Re-evaluate with a new battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I was just about to buy another original, but then I looked up other solutions and some people were saying that you need to calibrate a new battery, so I used the code and calibrated it and the flickering is gone. I am still going to buy a new battery as I have replaced batteries on other phones, including old Samsungs and this has never happened before, so I am going to buy another from another supplier just in case.
さんによる
コメントを追加
The other option to try is recalibration, I was bought another but calibration can fix it in some cases.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
80stechkid さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 32
今までの合計 751
