Can I replace the charging port?
The charging port on my headset is broken and i was wondering if i could replace it somehow on my own
You might be able to. Or at least replace the cable the charge port is on. I found a fairly thorough teardown of the device and it looks to me like the charge port is part of a flex cable which also carries signals from whatever other minor boards or components are on that side of the headset to the main board.
It looks like a bit of work, but doable if you can find a replacement part.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 748
