メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ゲーミングPCとは、ビデオゲームをプレイするために特別に設計および最適化されたパーソナルコンピュータです。
How to pc gaming
كيف اركب الحاسوب الكمبيوتر الموجودة في البيت
Translation
How to install a computer The computer in the house
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
@lkntlghmd we need more information to help you. What computer? What hardware? What are you trying to do?
さんによる 共有
コメントを追加
1 件の回答
I assume you mean how do you build a pc? if you're really not sure I'd suggest starting with a pre-built pc, there's many companies out there that admittedly at a higher cost than self-built will provide a pc built, set up with windows and usually under warranty too, as far as installing in your home, you'll have power leads, internet if you plan to connect wired or get a pc with a wireless adapter to connect to wifi, in addition to a pc tower/case you'll also need a monitor/screen, keyboard, mouse, ideally a mouse-mat under the mouse and should you so wish, a headset/speakers, as far as storage I strongly recommend having at least 2tb of storage, Ideally on an ssd instead of hdd as they're faster, quieter, and last longer.
hope this helps.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I would add that instead of going to a pre-built vendor, try checking your local computer store.
I don't know how this translates to OP's country, but I will build custom builds to meet my client's needs and usually come in about 10% less than the cost on PCPartPicker.com. I can save you significantly more than that, even, if you want certified refurbished parts.
(This does not apply to custom watercooling loops, as the time needed to do a loop properly is more than the time to build the entire rest of the PC, and my labor is priced accordingly.)
Going to a boutique builder who does super intense cable management and powercoated cases is going to cost you, and in my experience most pre-builds skimp out on important (but not flashy) details like cooling and PSU, but finding a local store who buys the same parts you can buy yourself and assembles it for you is oftentimes cheaper than just buying the same parts yourself.
さんによる 共有
コメントを追加
回答を追加する
القنات الغامضا さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 657
