メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 8 Proは、OnePlusが2020年5月に発売したAndroidスマートフォンです。このページでは、地域別モデルIN2023とAndroidビルド名OnePlus8Proについて解説します。
Fingerprint Sensor Not Working After Screen Replacement
So yesterday I had my screen replaced (was grenaded after it met my bed frame edge) and it all went perfectly fine. The only thing that bothers me now is the fingerprint reader. I can register new fingerprints without a hitch like normal, so I know it's working fine, but after setup my fingerprint just doesn't work, like something is suddenly making it not read. Has anyone else ran into this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
7件の回答
最も参考になった回答
If you transferred the original finger print sensor from the old display to the new one, it typically requires recalibration. If not, then the finerprint sensor is programmed to that specific device and a new or replacement one won't work without reprogramming it. As far as I know, oneplus doesn't make the reprogramming software publicly available. Thanks, OnePlus!
This one on eBay should do the trick https://www.ebay.com/itm/275420607111?ch...
This guide should help as well https://www.youtube.com/watch?v=FsZFyGXc...
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Oh wow, that's odd. I would've thought that with the sensor being in-built that it would just be plug and play like the display and literally every other capacitive thing with it. I haven't tried the usual troubleshooting like rebooting and such (and I'm not factory resetting this phone unless I'm selling it). Guess I'll see where the links you provided get me. Is that same tool available on Amazon by chance?
さんによる
If you can register new prints have you removed any old prints then tried again?
さんによる
@razorx you'd think it would work like that but no. I haven't seen it on amazon but it's worth a shot to check
さんによる
How can you reprogram the fingerprint sensor?
さんによる
コメントを追加
OnePlus said that no calibration is necessary after installing a replacement screen and digitizer on the OnePlus 8 Pro. Current as of 06/10/2023.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@schleems18 it must be necessary surely. Otherwise how does my fingerprint register fine but never works in practice?
さんによる
I haven't attempted changing or adding a new fingerprint, everything functioned as it had before the screen replacement. Have you tried a factory reset? You could also try adding the same finger a couple times, just in case.
さんによる
@schleems18 I'd much prefer not factory resetting, I don't want to go through the faff of recovering everything. And I did try adding a couple times, no avail. As of late I've just been living without it
さんによる
I'm facing the same issue
さんによる
コメントを追加
phone display not on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
how to on phone dispaly
さんによる
コメントを追加
Fingerprint issue
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Fingerprint scanner issue
さんによる
コメントを追加
Will it work after a hard reset??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have faced that problem after display Replacement in oneplus 8 pro. Any solution here plz?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
fingerprint not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Razor X さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 58
今までの合計 10,149
