Where can I get a replacement display?
I recently dropped my phone face down on rocks and the display has been destroyed. Is there a place I can get a identical display replacement for my phone? Also, I live in the USA.
Since this is a fairly new phone model with an OLED screen, replacements aren't cheap, but then again, they're a lot less than the cost of a new phone. Here are some examples; if you do an internet search for something like, "Samsung Galaxy S21 FE screen replacement" you can find more.
Samsung Galaxy S21 FE 5G OLED and Touch Screen Replacement – Repairs Universe
Samsung Galaxy S21 FE 5G Screen Replacement Kits & Parts – PhoneRemedies
You can also check sites like eBay and AliExpress who frequently have lower prices, but you sometimes take a chance on quality. It appears the color of your phone is a factor in selecting a replacement screen, so keep that in mind.
Instructions would probably be nice too, I imagine. Here's a guide for replacing the LCD+frame assembly.
Samsung Galaxy S21 FE 5G screen replacement - repair guide
Good luck; that should get you started. Don't forget a sheet of precut adhesive to glue the rear cover back on and help restore most of the waterproofing.
Note that you can buy replacement screens with or without the frame; the only written instructions I was able to locate are for the version with the frame, but you can find YouTube videos of the procedure to use when replacing just the OLED display without the frame.
このアンサーは役に立ちましたか?
Here is a place that sells what you are looking for. I am not able to tell you if this is a reliable resource. https://phoneremedies.com/collections/sa...
このアンサーは役に立ちましたか?
Were you able to get a replacement screen for your phone? If not please refer to previous posts. If you already have a replacement screen and just need directions to complete your repair. Why don't you do a web search like this, "Directions to repair Samsung Galaxy S21 FE".
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 11
過去 30 日: 66
今までの合計 4,528
4 件のコメント
what country are you in
daniel さんによる
@tech_ni The USA
Joshua Walters さんによる
@joshuawalters https://www.mobilesentrix.com/catalogsea...
daniel さんによる
https://cellpartsworld.com/
https://www.mobilenzo.com/
https://gadgetfix.com/
https://parts4cells.com/
Hope these help, there's more but all similar lol
Michael さんによる
