メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D7000は、2010年に発売された16.2メガピクセルのデジタル一眼レフカメラです。
Why the auto-focus does not work?
Just wondering if there is any way to fix the auto-focus on my Nikon D7000.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If I remember correctly the focus sensor is on the bottom of the mirror box, within the mirror unit a second mirror aims some of the reflected light heading to the eyepiece downward. So could the secondary mirror not be coming back down when the shutter release is pressed? Is the viewfinder image visible in case the main mirror is getting stuck.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I don't know that much about the guts of camera. But it does work at times.
How would you fix that if that is my problem?
さんによる 共有
@benjamin95833 - I would take the lens off and put the camera into a long manual shutter speed and looking carefully how the main mirror reacts, is it going up as fast as going down? I would run it a few times and if you have a cool place put the camera there (keep it dry) repeat to see if the lube had gotten gummy. After watching the primary mirror you put should see at an angle a second mirror which aims the light down. Again watch what it does did it get stuck?
The issue you face it’s a bit tricky to clean the hinge pin and lube it again without getting the detector dirty which you really don’t want to do.
This may need a good camera repair person to fix this.
さんによる 共有
@danj - Thanks I'll give that a try a see what I can figure out. Thanks again for your time and effort it's much appreciated.
さんによる 共有
コメントを追加
回答を追加する
Benjamin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 33
今までの合計 540
