How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
このアンサーは役に立ちましたか?
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
このアンサーは役に立ちましたか?
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
このアンサーは役に立ちましたか?
Use wireless charger
このアンサーは役に立ちましたか?
Might depend on which model version it is, as the OP didn't specify.
The Moto Stylus 5G (released in 2021) doesn't have wireless charging capability.
The Moto Stylus 5G (2025) model does.
過去 24時間: 3
過去 7 日: 8
過去 30 日: 51
今までの合計 2,706
2 件のコメント
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
jayeff さんによる
هذه المشكله من أهم المشاكل لواجهها
Translation Arabic - English
This problem is one of the most important problems to face.
ابو عبود さんによる
