メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
カラーレーザープリンター
Is there a fuse there?
Where is located the fuse and how can I approach it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
There are numerous fuses. Can you describe the symptoms?
さんによる
The printer does not show any sign of life after an unclear power interruption.
さんによる
コメントを追加
1 件の回答
Try the following methods to restore power to the Brother machine:
3.1 Method 1
  1. Remove the power cord for at least 30 seconds.
  2. Press and hold the ON/OFF button down, and then insert the power cord back into the machine.
  3. Do not release the ON/OFF button until the machine has been powered on completely or after 15 seconds.
  4. Repeat this procedure up to three times if necessary.
3.2 method 2
  2. Remove the paper tray from the machine.
  3. Reconnect the power cord, and then power the machine on.
  4. When the machine has been powered on completely, insert the paper tray back into the machine.
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
さんによる
コメントを追加
回答を追加する
tvarozna さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 31
今までの合計 1,100
