メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Anbernic RG353Vは、レトロゲーム愛好家向けに設計された携帯型ゲームコンソールです。鮮やかな発色と広い視野角を実現するIPSディスプレイを搭載しており、ゲームプレイの楽しさをさらに高めます。
Does not turn on
Just bought it. Played about a 30min then charged it to 100%. Then played again for a while, around 15 minutes. After that console did hang. Tried to reset it, but it does not turn on at all for now...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Faulty Power Adapter
  1. Check to see that both the adapter and the cord are undamaged.
  2. If the cord is plugged in and the Anbernic shows a bright yellow light, the Anbernic is charging. Try to turn it on after 10 - 20 seconds.
  3. If the yellow light doesn’t show, consider getting a new cord. (Make sure that the cord is the correct type.)
  4. If getting a new cord fails then it might mean that the battery no longer works and you will need to buy a replacement battery.
Stuck Button
  • There might have been debris or dust that got stuck into the button.
  • If you fail to find dust or debris then get a screw driver and unscrew the Anbernic to try and manually fix the button that is stuck.
  • If you find debris or dust, you will have to find a soft and dry object that you can use to clean the button to help it get unstuck.(usually an old toothbrush should do the trick.)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nyo Nor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 29
今までの合計 830
