メインコンテンツにスキップ
Apple設計のM1 ProとM1 MaxのSoCを搭載した14インチMacBook Proの修理ガイドと分解情報をご紹介します。2021年10月に発売。モデル番号はA2442。
75回答 すべてを表示
Last 2 rows of keyboard are uneven enlightened after repair
Hello, I had to repair my Macbook Pro m1 14" few days ago because I spilled a coffee on it (yes it had sugar in it). The repairman changed the keyboard because the keys were stuck due to sugar caught in the mechanisms but now I see that the last 2 rows of my keyboard are less bright than the rest of the keyboard, what can cause this problem ? Note that the area where i spilled the coffee is not the same that the area that is now less bright, that's why I am confused.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Behind the keyboard is the backlight sheet which is a light defuser to even out the light from the mounted LEDs within the sheet. So between the spill staining the defuser and/or one or more of the LEDs is not lit either because of corrosion or burnt out.
Other they replacing the uppercase assembly (the only way Apple sells the part) you will need to find a junker which has a good backlight sheet.
I think it’s best to just live with it, sorry.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antoine LABONNE さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 115
