メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
現在は Briggs & Stratton が所有する Murray ブランドの乗用芝刈り機に関する修理ガイドとサポート情報です。
Murray mower will not start
We replaced the starter,battery,fresh fuel and seniold. When we try to start it trys but enough to kick over.
We replaced the battery cables and still wouldnt turn all the way over. My husband says that it does not spark. Do you have any other suggestions? Model number 309304x8 Murry 11hp briggs
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
3 件のコメント
Murray 309001x08A - Turfmaster 30" Mid-Engine Rider (2009) (Home Depot)
Won’t start, it doesn’t turn over at all. I replaced the fuel tank and drove it around the yard and it ran good. I tried to crank it the next day and nothing. My Battery Tender charger and multimeter show the battery is good, over 12.5 volts. I replaced the stater solenoid, brake and seat safety switches and it just makes a slight kinda clang sound once and that’s it.
さんによる 共有
Mine was like that Bob found out the startingmotorwas jammed and out of sync
さんによる 共有
kev2e1kjb
How did you fix it? My Murray 15.5 hp widebody riding mower did the same thing, had it running fine then started it up this past sunday and had nothing, not even tried to start or turn over. Brand new battery and fuel filter and fuel tank and spark plug. Ran like a charm before so I cut the seat safety switch as I have read thats an issue with them, still the same thing so I replaced the ignition switch, still nothing but noticed now its blowing fuses, even when I dont try to crank it over Ill put a new fuse in and it blows it immedietly. Didnt do that before until I cut the seat safety switch, tried keeping the wires apart and together doesnt make a difference. Im at a loss of how to get it to start and stop blowing fuses. Please help if you can.
さんによる 共有
コメントを追加
9件の回答
ベストアンサー
First off, there was a recall on those mowers due to leaking gas tank. For that check check on here. Now lets assume this got fixed;-) You need at least three things for the mower to start. Fuel, air, and a spark. Check for gas, clogged filters and collapsed lines. Check your carburetor, make sure your float is working right and that your needle valve is clean. Check all the lines for leaks and proper connection. If you are sure you do not have spark, then disconnect the Shut Off Wire at the Control Bracket and then check for spark at the Plug. If there is still no spark at the Plug, disconnect the Shut Off Wire at the Coil and check for spark. If you should still not have a spark, it is possible that your coil/or the ignition module is Bad. You can check and see that the Coil/Ign Module to flywheel gap is .020in. If you get spark at the Plug anytime during these checks, then a Safety Switch or Wire May be the Problem. The engine will turn over with a bad safety switch but will not fire. There should also be a blade safety switch, that you do not want to forget to check as well as the seat safety switch. To really isolate what is going on, I would disconnect the safety switches, bridge the wires. That way, you should be left with just the ignition circuit. If you now get spark, you know that it is one of the safety switches. reconnect one at a time and see which one causes the failure. Replace the safety switch. DO NOT OPERATE THE EQUIPMENT WITHOUT THE SAFETY FEATURES. Check the electrical diagram and see if that will help you further along. Good Luck and let us know how it is going.
画像
このアンサーは役に立ちましたか?
スコア 12
11 件のコメント:
Thank You for all your help. I was finally able to get it started after all that checking, looks like it was the Magneto Coil. When I put it in it started right up like new agian. Thanks alot.
さんによる 共有
Great job in fixing it. Thanks for accepting my answer. All the best to you...:-)
さんによる 共有
Do you by chance have the belt diagram for that model?
さんによる 共有
Which wires do u connect to by pass sensors and where? Got fire and got fuel but won't start
さんによる 共有
my mower starts but as soon as you let off brake it stalls,also when engaging blades it stalls.
さんによる 共有
6件以上のコメントを表示
コメントを追加
この回答は他の質問に帰属しています。
Wendy,
Try replacing the battery terminal wires on both the ground and the positive of the battery (black and red wires) with new. Current is not always able to flow through old, deteriorated or frayed wiring. That is the only link in the chain so far that you have not replaced.
After that you may try cleaning your battery posts and terminals with a "post and terminal" cleaning tool.
Let us know if that works or if it is a different problem.
Good luck,
Frank
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ I've also seen stranded battery wire that the corrosion has migrated into the interior wire. It was weird cutting into the outer covering and finding corroded wire way into the covered wire
さんによる 共有
コメントを追加
murry 30"riding mower, hit a rock with blade while running, engine died, now when l try to start it will do nothing, no click or sound at all? where would l start to look?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Evidently the silenoid is bad, my husbsnd wants to bypass it becsuse it will run when screw driver is placed across those screws. I realize this is not optimum but can it be bypassed
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
it is highly unsafe due to the amount of exposed metal but yes it is possiable
さんによる 共有
Ok so I got the 15hp tech riding lawn mower (Murry) I get on push clutch set brake , tried to start it turned over , but it now on 2nd try it tries but seems something is stopping it , I can spin main front pully and again tries even got more turn over but something is not letting it fully crank, its like it's locked
さんによる 共有
コメントを追加
Hi! I have a question. If somebody speak spanish it will be better.
I changed the battery and the spark plug. When I try to turning on.. the engine does not rotates completely, but if I remove the spark plug the engine rotates. What can be the problem???
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
sounds like you would have a pressure build up which could indcate a stuck valve or loose rocker arm
さんによる 共有
si la batería está débil, intente con el cable de puente de su automóvil.
If battery is weak, try jumper cable from your car.
さんによる 共有
I'm have the same problem right now cant get a full turn. I did the jump cables and still did it to apart carburetor cleaned it real good, nothing. Took out plug turned over and over again plug back in yeah you guessed it, how do I clean it without tearing it upart
さんによる 共有
I've had this problem in the past and it was due to the valve clearances being incorrect. 20 minutes work to fix. 3-5 thou IN, 5-7 thou EXH.
さんによる 共有
コメントを追加
hi like a few others i was cutting the lawn hit an uneven lump stopped not worked since replaced the solinoid nothing , please help kevin
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
we'll need more information but what i would check first is does the battery have power if so make sure the blades are off if so make sure the brake is on and there is gas in the tank try that first
さんによる 共有
You probably sheared the flywheel key. Go to you tube and search how to change sheared fly wheel key. There are great videos to show how to fix this issue.
さんによる 共有
I have a older Murray lawn tractor 12.5 hp it has no fire unless I unplug kill wire on coil
さんによる 共有
Ones who have hit something and mower won't start mowers have a shear sheer pin in the motor to keep hitting things from ruining the engine replace sheer pin should start up
さんによる 共有
コメントを追加
この回答は他の質問に帰属しています。
my murray mower just died one day and haven been able to get started sinse.checked all safety switches got new sparkplug new carbuater.drained fuel tank put fresh gas in. motor turns over but will not start. getting spark no gas getting to combustion chamber. when I took out spark plug no gas on it. I have a briggs and Stratton motor 28R707-1120-E1
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
Hello. I just purchased a Husqvarna rz4621 when I turn the key to start it barely turns. Battery is good. Out jumped cables on it didn't help. Took spark plug out. Have plenty of spark. Turn key while plug is out and motor cranks over fine. Put spark plug back in and motor doesn't wanna turn again. Not sure what I'm missing?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hello I have a 14.5 Briggs & Stratton motor Replaced the battery and the solenoid all it will do is Click motor does not turn over I spend the crank pulley by hand so it does not froze up wondering about the starter any ideas
さんによる 共有
@redneckracing05 did you get a solution. I have same mower, exactly the same problem!
さんによる 共有
I have the same issue with a 16hp.
さんによる 共有
コメントを追加
Was anyone able to find a battery replacement for a mt100 riding lawn mower?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
wendy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 97
今までの合計 98,118
