メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy A7 (2017) は、Galaxy Aシリーズの中価格帯スマートフォンです。2017年1月にSamsung Galaxy A3 (2017) および A5 (2017) と共に発表されました。
How to replace a shattered back glass?
My samsung is in pretty bad shape. Since the back glass is open and shattered, the water resistance capability is useless since it is opened like an egg. Can somebody help me with the repair it means a lot for me. Thank you very much.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Use something, hair dryer etc to heat up the adhesive around the frame and peel the back away. Clean up any remaining adhesive then fit a new adhesive and back.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Thanks a lot for the help! But I'm wondering if it is safe to submerge my phone in water for under water pictures. And I think when I'm installing the back glass I did a terrible job. Also I bought the back glass in lazada, it is an online store here in SE Asia. Should I add some extra adhesive to be water resistance?
さんによる
@enricogabr24424 Absolutely not. Any water resistance that the phone is rated for is negated the moment the phone is opened. Even the best professional replacement cannot requalify the water resistance rating. Done correctly, your phone will be mostly waterproof and will probably survive exposure to water, but unless you want to be buying a new phone due to water damage, do not attempt underwater photos with a phone that's been compromised.
I'd suggest a waterproof pouch to put the phone in if you want to use it for underwater pictures.
さんによる
@enricogabr24424 Never ever submerge a phone in water. I've had so called 'waterproof' phones come in for repair after water damage. If you want to take underwater pictures buy a go pro or a action camera.
さんによる
Thanks for letting me know.
さんによる
شكرا جزيلا لكم
さんによる
コメントを追加
回答を追加する
Enrico さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 31
今までの合計 710
