メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Envy x360 m6-aq103dxは、タッチスクリーンと360°回転機能を備え、ノートパソコンとタブレットを1台でこなしたいユーザーに適した2-in-1デバイスです。モデル番号:W2K45UA。
Error Code on Caps Lock
Every now and then I would get this error code and it would go away and now it's constantly doing it.
Caps Lock Error:
3 Long
2 Short
I took the screen off to see any loose cables and there were none, also took the bottom cover to check and same result. I thought about changing the CMOS batter this board has but idk how to take that out. Any recommendations would be great.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
The issue was one of my RAM sticks went bad. Thank you @flannelistt (Alisha C)
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
If I remember correctly, 3 long, 2 short is most likely a RAM issue for most HP models. In fact, blink codes in general are most often cleared on laptops by a simple reseat of your RAM.
That seems to coincide with your “every now and then” sort of experience. Maybe one of the sticks is just loose.
If you confirm the exact model number of the machine, we can probably confirm this and get some service documentation. But I would pop off the bottom off the laptop, unplug the battery (the regular one, not the CMOS one), then pull your RAM stick(s) out, then put them back in and see if you’re in business.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
HP Envy x360 m6-aq103dx as it says on the back.
さんによる 共有
@xfuskyx Just making sure, with Windows machines, there are so many I always want to be certain. The Service Manual will give you the rundown on how to get the unit open, how to disconnect the battery, the RAM, even the CMOS battery if you wanted to give that a try.
さんによる 共有
Thank you, I'll give this a try and update you.
さんによる 共有
Ended up being one of the RAM sticks. Thank you.
さんによる 共有
@xfuskyx My pleasure. Glad it was an easy fix!
さんによる 共有
コメントを追加
回答を追加する
Bryan Fuscarino さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 50
今までの合計 1,411
