メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AirMac Extremeベースステーションと同時に発売されたこのハードディスクを搭載したモデルは、802.11ac対応のタイムカプセルNASです。
Access Time Capsule files from Linux
画像
Hi iFixers 👋
I've been looking into this for years and still can't find a solution: has anyone maybe finally managed to access TimeCapsule files from Linux?
I've been all over the internet many times and tried over AFP and SMB - it still shows some weird error and nothing happens 🤷
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント:
I actually found this today:
https://askubuntu.com/questions/1094087/...
Will give it a try and let you guys know if it works.
Not really the most effortless approach, but whatever works
さんによる 共有
コメントを追加
1 件の回答
Are you able to access it using a Mac system?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Hi, sure, on anything other than Linux it works just fine.
さんによる 共有
@insympathy
Just wondering if this would help depending on what type of file system is used by the files on the Time Capsule
さんによる 共有
Hi 👋🏻 thanks for sharing, bit the system used is not yet APFS - it’s HFS+ and even that doesn’t really matter because I’m mounting it as a network resource and not directly as a physical device, that’s why my only options are AFP and SMB protocols
さんによる 共有
@insympathy - SMB is a bit of a wacky of a protocol as it can sit on top of NETBIOS or over UDP as well as TCP! MicroSoft also altered its implementation as well as it’s Port assignment.
Here’s a useful backgrounder IBM - Red Hat SMC Protocol
I would setup an Ethereal sniffer to monitor the dialog so see what’s happing on the wire. Here’s a good writeup SMC-R Interpretation Series – Part 1 and SMC-R Interpretation Series – Part 2
It’s been years since I’ve worked on SMC, I just don’t remember what Apple did and clearly this is a dead product offering so they won’t be updating it.
さんによる 共有
コメントを追加
回答を追加する
in_sympathy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 36
今までの合計 1,799
