Green power Light keeps blinking
Green power Light keep blinking
この質問は役に立ちましたか?
Hi,
Press and hold the power button operated for >10 seconds and then release to ensure that the PC has fully shutdown in case it is in a sleep or hibernate state.
Once it has shut down try turning it on and check if it starts OK
If it doesn't start and boot into the OS then try a power refresh and check if that resolves the problem.
If it turns on OK there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset. Once the D&T have been corrected the message won't appear the next time that the PC is started.
このアンサーは役に立ちましたか?
Thanx I'll try getting another battery
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 563
