メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
When I open the lid, screen fades to white and goes flickery
When the lid is opened past 30 degrees the screen starts to fade to white and flickers untill you can barely see what is on the screen.
When you close the lid back to 30 degrees its like a switch and screen comes back to normal.
Otherwise works perfectly. Works to external screen ok.
I know older machines had probs with screen cable but they seem to result on screen going black.
Thanks in advance for any help
2018 macbook pro A1989 i7 2.7GHz 16Gb ram
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Yes, the older 2016/17 systems had a backlight cable issue what was called FlexGate!
In your case the issue is within the T-CON board and the LCD panel. There is a set of cables which connect between them so the board can paint the screens image. The reset signal is not working so the screen just additively adds the following image on top.
Sadly, you’ll need a new display assembly MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide MacBook Pro 13インチ Touch Bar 2018 スクリーンの交換
Replace a display compatible with a Mid 2018 to Mid 2019 model A1989 or A2159 MacBook Pro 13" with laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, and Clutch Hinges.の画像
製品
$449.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi
I believe you have a issue called "flexgate" ;-{
Flexgate is where the screen cables start to break apart and perish
I was testing a A1989 MacBook Pro's screen a day or so ago and it had the exact same issue as what you are reporting
unfortunately the only long term fix is to ether have the display cables replaced which hardly any people do or have the display assembly replaced
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I thought the 2018 model had been fixed?
I thought I would probably need new screen, ouch!!
Oh well better dig deep and shell out.
Thanks for replies
さんによる
@alanhancock31
Yeah they ”fixed” it
In all fairness on the 2018 and above they did make the screen cables longer to try and avoid the issue but it unfortunately does still come about it’s just not as common
さんによる
@hellomacos @alanhancock31 - Here’s a good write up on FlexGate https://www.ifixit.com/News/16943/macboo... and the 2018 onward systems don’t encounter the issue as you can see better explained here https://www.ifixit.com/News/13979/apples.... That still doesn’t mean you still can’t encounter a backlight issue! A good bang along the black clutch cover or something wedged between the uppercase and the display bottom edge (chin-plate) which is a thin piece of glass which covers the cables going to the LCD panel can be damaged. The backlight goes out, black not white
さんによる
コメントを追加
回答を追加する
alanhancock31 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 584
