メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
CDMA 3Gセルラーネットワーク(Verizon)に対応した第2世代Apple iPadの修理ガイド、分解、トラブルシューティング情報です。16、32、64GBのストレージオプションがあります。デュアルコアプロセッサであるA5を搭載しています。2011年3月発売。モデル番号A1397で識別されます。修理には熱と慎重なこじ開け作業が必要です。
Transfer Data From Dead Logic Board?
Hi all,
This is my first question, so please bear with me as I figure this out.
I have a iPad 2 CDMA (64GB) that had the battery swell up and explode (no one was injured other then the iPad itself), and it killed the screen, case, and the logic board. I bought the same model on eBay to try and swap the parts, and after I tested individual components with the new ones, I know that the logic board is dead, although I did get a relevant current draw when the power button is pressed. .
Since I know the logic board is dead, I used the iPad 2 Teardown Guide to locate the NAND flash chips, and attempt to transfer them to the new logic board. The only issue is that I ripped a few PCB pads during the de-soldering process of the original chip on the new logic board.
Is it possible to fix the ripped traces, or do I need another new logic board? Also, is this idea to recover the data even feasible? Since I haven't touched the original logic board with the data yet, those chips are still soldered on, so I obviously need a few tips on removing those as well.
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
It's deceased, I wouldn't waste your time.
さんによる
コメントを追加
2件の回答
ベストアンサー
It's not possible to recover data this way by replacing just the NAND chips. The data on them are encrypted with keys only known to the CPU, you need to migrate the CPU onto a new board as well.
Fixing ripped pads under the NAND chips or on the board is possible.
https://www.bilibili.com/video/BV1Ci4y1R...
https://www.bilibili.com/video/BV1vW411C...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Great, Thanks! One more thing though. Do you have any tips with the hot air station so this doesn’t happen again? My previous settings were 400C at 50% blower speed. That seemed to be the minimum to get the chip to come off, so I must not be doing something correctly.
さんによる
コメントを追加
I think I got it, but now the iPad is boot-looping. Any suggestions? Thanks.
Edit: I just left the iPad sitting there for an hour or so, and it finally booted up. Thanks for the help!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
archaic_fixer さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 52
今までの合計 1,656
