メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの最もパワフルなiMac。3.2 GHz 8コア、3.0 GHz 10コア、2.5 GHz 14コア、もしくは2.3 GHz 18コア Xeon Wプロセッサを搭載。モデル番号はEMC 3144 / A1862 (ID iMacPro1,1)。
iMac Pro Front Camera Showing a Green Screen
My front facing camera will only display a green screen. I have allowed all permissions, unplugged and held down the power button to have a hard restart, and tried different apps and still the camera only displays a green screen. I did an apple hardware test and it said nothing was wrong. Trying to see if there is a how-to on replacing the camera and or any other tips on how to get it working. Software: Venture 13.2 (22D49)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The Apple diagnostics won’t check the discrete camera elements in this case the actual photo detector (CCD).
Did you have the system opened at any point? Is possible the camera unit it’s self got damaged.
I would bring it into an Apple Store and make sure to say to them you only want someone who has been trained on this system to work on it as I’ve heard some repairs of less skilled folks talking on this much harder and expensive system.
I’ll warn you they may just replace the display assembly as the camera is part of it. Try to get it covered under extended warranty if you can. Otherwise you may just want to go with an add-on camera as that would be cheaper!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jeff Jenkins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 288
