メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple製 12.9インチ iPad Pro (第6世代) の修理ガイドおよび分解情報。2022年10月18日発売。
How many NAND in each storage?
In various storage capacity specifications, how many NAND particles are there?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Apple doesn't add more chips to the board to increase the internal storage; instead they use a single chip that comes in different amounts of storage, from 128GB up to 2TB. So if you're thinking of increasing the disk storage on your iPad, you can't just add another chip; you have to remove the existing one, reball the circuit board and solder a new one on. Unless you're experienced at working with BGA components and microsoldering and have the necessary equipment, that's a job best left to professionals.
Does that answer your question, or were you referring to something else when you used the term "particles"?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you for replying this question. What I care about is the internal storage read and write speed. If 256GB uses two NANDs, the read and write speed will be faster than one.
さんによる 共有
@wa0327 - Yes that would be correct! Interleaving between them
さんによる 共有
コメントを追加
If you look at the iFixit teardown you’ll see two Flash chip locations so depending on the storage you bought one or two chips will be installed
Reference: 12.9” iPad Pro 2020 Teardown: What does the LiDAR scanner look like?
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
My Pad Pro is 2022 M2 12.9" 256GB, but the reference you provided is 2020.
さんによる 共有
@wa0327 - it’s the same layout! Just like how the MacBook Pro’s have a max of two Flash chips. In your case it’s a single chip.
さんによる 共有
Thank you for your replying Dan.
so, 128GB and 256GB both are single NAND chip, right?
さんによる 共有
@wa0327 - What is your concern here? The number of Flash cells doesn’t change because Apple used one or two chips.
さんによる 共有
Thank you for your replying, Dan. In order to get the fastest r/w speed, I would like to choose that model which has two chips.
さんによる 共有
2件以上のコメントを表示
コメントを追加
回答を追加する
wa0327 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 53
今までの合計 1,522
