メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Air 第2世代のセルラーモデル用修理ガイドです。
Will it run without the battery?
The battery is dead. It powers down within a minute or two after I unplug it. I'm concerned that the battery could develop issues, since it's dead and under charge 100% of the time.
Can I just pull the battery from it and reassemble it? I only use it plugged in at the moment. I realize it sounds weird, but it's an old iPad. (It's in the 'old folks home' part of its life) I really don't see using it seriously as a battery powered iPad depending on the battery, so why replace it. I just want it to be 'safe' if the battery decides to swell or overrun. In other words, I can't afford to replace it, and see no need to replace the battery, but would like to keep it working. Long question, I know...
Thanks...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
No, it needs the battery. Easiest way is just to order a cheap battery to replace the one in it since you plan on opening anyway.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
100% can confirm. These will not boot all the way most of the time without an installed battery.
さんによる
コメントを追加
回答を追加する
RobCow さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 60
今までの合計 2,295
