メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod won't power on after screen replacement, even when plugged in
I just replaced the screen on my iPod, tearing the copper tape on the back of the rear camera in the process. When I first tested it, the power button didn't work—but it turned on after I plugged it in and worked fine. I disassembled it and found nothing wrong with the power/volume ribbon cable or anything else. Upon reassembly, it will no longer power on at all, even when plugged in. Any ideas as to what might be going on here?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
10 件のコメント
is it recognised in itunes? perhaps the LCD is disconnected/damaged.
さんによる
No, it isn't recognized by the computer at all.
さんによる
Also, I tested it with another replacement screen, and it had the same issue.
さんによる
I am also having the same issue, i repaired the screen like I have on 100's before and now the device is non responsive
さんによる
I AM having the same prob
さんによる
5件以上のコメントを表示
コメントを追加
61件の回答
ベストアンサー
If you get problems powering up after screen swap, locate the 3 battery terminal beneath the metal cover. Refer to the battery replacement guide to see what the terminal looks like. Find the +3.7 volt terminal using a multimeter (From memory, it's the one on the right as you look at it.), and short this terminal briefly to ground. (The metal plate surrounding the home button will do.) Then, plug the phone into a charger, and within seconds you should get your confirmation beep and the screen should show that the phone is charging. Wait a minute or so, and it will boot up.
This has worked for me on more than a few occasions. I hope it helps
このアンサーは役に立ちましたか?
スコア 21
24 件のコメント:
I had the same issue and tried out what Rob suggested. I got it to turn on and the lcd to show a white screen by shorting the rightmost of the three battery terminals and holding the power button down at the same time while plugged into a charger. Didn't seem to work without holding down the power button at the same time.
さんによる
Same problem here...no power after screen swap. I used Robs suggestion (grounded battery terminal) and worked for me! Thanks!!
さんによる
Rob and Chuck H, how did you ground the battery?
さんによる
RE: Rob and Chuck H, how did you ground the battery?
I used the little screwdriver that came with the kit and touched the solder post on the battery (third one to the right with the home bottom at the bottom) and the metal housing around the home button. I had to try several times but it eventually worked. You can also try holding the sleep button down when attempting this. Good luck!
さんによる
I'm new and I don't know how to reply to someone inside a thread but @rob could you explain your solution to me really simply, how and what do I ground and what should i use?
さんによる
19件以上のコメントを表示
コメントを追加
Here's a tutorial with pics that everyone has been requesting. I've used this method over a dozen times successfully. Good Luck!!
There are 3 small battery terminals (shown below). You only want to touch the one to the far right (circled below). Avoid touching the other 2 terminals!!
このアンサーは役に立ちましたか?
スコア 20
15 件のコメント:
So I have the same problem but @Chuck H, I just gave this a shot and it was unplugged and it sparked when I tried, I then plugged it in and tried to turn it on but nothing, another guy told be that there was a short somewhere and it would be really hard to find, any input for me?
== Update ==
@Chuck
Well I tried again several times, triple checked the screen connections, even tried another screen to be sure it was the current one, but it still wont turn on, but your saying that because it sparked its not shorted right? but yeah any other ideas?
さんによる
i just did this and the ipod came on but now it's stuck in recovery mode and it keeps telling me to plug into itunes, i have done all the resets nothing helps
さんによる
@Malti
Sounds like your screen is fixed if you can see the usb cord plugged into itunes. You have a whole different situation going on. You have to put your ipod in DFU mode (Google DFU mode if do not know how to do this) and then plug it into itunes. Your ipod will be restored to the most current firmware from Apple.
@Jon
A spark is normal. I actually will keep contact on the battery terminal and metal until I see a spark. So your ipod is not shorted out.
1) Make sure both connectors from the screen are connected to the ipod.
2) Make sure your battery has some charge and not completely dead.
If both of these are not the problem then ground it again. Sometimes it will take 2-5 tries until it will work. Also, just plug it in and it will boot on its own...no need to hit the home or sleep button.
Good Luck to you both!!
さんによる
@Chuck
さんによる
@jon
Yes, I am saying that a spark is not an indication of a short. The only other thing I can suggest is to try and reset the ipod. Hold the sleep & home button simultaneously for 10 seconds or until you see the Apple boot logo.
さんによる
10件以上のコメントを表示
コメントを追加
What actually happens is when u don't turn off ur iPod before changing to the new screen the circuit board shuts down. But only temporarily the easiest way to fix this problem is to put it up n let it die Completely. N be patient it will take a while depending on how much ur battery was on and I know it works from experience it happens to me 3 times already my battery was at least at 70 percent and it took from 7pm to at least 4pm for it to die. If it's full wait at least 2 1/5 days then plug it in n it should be charging within seconds if that doesn't work then ground it
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
so ive been fixing an ipod touch 4th gen and had this exact problem. i replaced the screen. turned it on and got a white screen. turned it off then no matter what i was stuck with a black screen. i tried all the trick above including grounding, hard reset plugging the charger in ect ect ect. nothing worked.
please note that my solution will wipe all of the data and reset the ipod completly.
what i ended up doing was plugging the ipod into the computer. i tuned did not reconise it and the screen remained black, i then put the ipod into dfu mode (power button for 3 seconds, power button and home button for 15 seconds, then the home button for 5 seconds.
itunes then recognised the ipod, note that the screen remained black.
itunes downloaded the latest firmwhere, and began the restore process. the ipod screen remained black until it began to reset. the apple logo with the loading bar appeared and once it was completed th ipod was working again,
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I GOT IT!! 1. connect the LCD cable 2. try to turn it on before sticking it down. 3. if black or white screen do a hard re-set, this can be done by pressing and holding the home button and the sleep/wake button on the top
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
画像の内容を見る:
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi all i have this prob quite alot, it happens when you unplug the screen wile its turned on, IT must be turned off before unpluging the screen or it shuts the ipod down and will not turn on or connect to itunes, ive tryed shorting the battry out and didnt work for me, so ive found the thing to do is let ipod go completly flat before screen change, ive never had the prob since. Good luck
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is exactly what happened to me. Now I left the ipod for 3 days hoping it would be dead, and plugged in the charger, but nothing happend, still only blackscreen. I would greatly appreciate any further advices. Thx
さんによる
コメントを追加
I changed the screen without turning it off and not it will not power back on. Will the battery run down even though it is turned off?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks Mike, I looked into the risks of installing the battery myself and how much it costs to get it repaired. I'm thinking I may just bring it into a repair shop nearby and see what the pros say and what I can get it fixed for. Thanks!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I was having this same problem and after messing with it for a few days i finally got it to display a white screen. Before this it would not power on, or be recognized with itunes. I tried the hard reset and it did not work. Tested it with itunes and with the white screen it was recognized. Couldnt get the white screen to go away for the life of me. Until i figured maybe the LCD was bad. Exchanged the LCD for a different one and got the white screen AGAIN... hard reset worked this time (power button and home button til ipod reboots) and it booted up just fine. I think the problem I had with the original no power was just not having a connection sealed all the way. It looks and felt like they were but after taking apart and making sure all connections were snug it finally powered back on. Try connecting it to a wall charge via A/C and see if you get a result doing that.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have you even read this thread? There are numerous confirmed solutions right here if you read. It's not caused by one single problem.. that's why you have to troubleshoot and find out exactly what it is. It could possibly be a faulty screen, also make sure to double and triple check your connections are secure. Including the camera connections, and inspect all ribbon cables with magnification to make sure none of them have been torn/disconnected from solder points.
さんによる
コメントを追加
Make sure that all cables are plugged in, and that no cables are damaged. If you used a heat gun, it may be possible that you accidentally fried a cable while melting the adhisive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you tried shorting the 3.7V (i think) to ground. I have this happen every once in a while when replacing the screens. You only have to short it for a few seconds.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi guys, yesterday i tried to replace the screen, and when trying to connect the black lcd screen connector i notice that it didnt fit like the original one, so i connected the old one again (the broken screen). Now im having the same problem, it wont turn on, i dont understand the battery thing, i tried it though.
Note: when i was connecting the screen, the wifi connection (that brownish thing that is on top right next to the screen connector got loose, i think i put it back in the right place.
Thanks for any help.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
are you shorting it and then plugging it in?
さんによる
whom are you asking?
さんによる
Sorry oldturkey03 kinda a noob to the forums ;)
reply was @Francisco Lastra
さんによる
コメントを追加
i shorted out the connection after a screen replacement, it worked perfectly but now it is saying the ipod is disabled for 5060 mins. anybody know why this is or if i did something wrong. also a soloution would be nice so i could give the ipod back without waiting 3 days.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Dose anyone know weather or not the screen will work if the digitizer cable has a tear?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I may have some useful info for those that aren't having any luck with this process. Prior to trying this I checked the voltage of the battery which was 3.7 volts, fully charged. After following this process without success I found after each spark the battery voltage had dropped to a low 1.0 volt, it would then require me to recharge the battery before I was able to get additional sparks. Is it normal for the volts to drop so low after a spark ???
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. I was wondering if someone could upload a video of this process? Would be very helpful :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried the ground and the screen came on but when I tried to swipe my finger across the screen before closing it up... It would not work. Any suggestions?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It means the digitizer isnt completely connected or its bad.
さんによる
コメントを追加
I just replaced my screen and yesterday it had a white screen, but no longer does. I am letting it die, but don't know how long that will take. How am I supposed to get something other than the white screen? I have no idea what to do and I already tried grounding it!!!!! :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've tried everything you guys have posted so far and nothing has happened. i checked all the wires and nothing is broken, i cant figure out what it could be. any ideas?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hello when taking middle metal frame plate by the power connection solder look pictures often people pry the black protection tape to much and slide plastic tool over the small bridges and break them if ony a few are broken you can bypass them with solder nut a very difficult task
please see picture on where these bridges are
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
billy,
This is my problem what do you mean by solder nut
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
also when changing screens make shure to blow canned air in the ports to remove glass shards. olus use a emeryboad to clean contacts from sticky tape and blow out again. i have had that happen before. plus the ground straps dont do much dont worry if busted i have done over 72 ipod repairs and 2 with trouble
Update
when taking middle metal frame plate by the power connection on left side of ipod i got a paiter putty knife to slide between the ribbon cable and metal frame. this keeps it from being glude to back of plate. when plate is off i use a small amount of superglue jell tolock down ribbon cable so it doesnt tear when connecting ribbon cable for digitizer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
HI,
The short on 3 worked great! I wondering why this is necessary??
Thanks,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey,
In the same boat as so many here - iPod just not coming on after replacement, done so many successfully too!!
With the shorting, i aint getting a spark - do i need to remove the tape over the solder to get a good connection..?
Thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So very helpful and interesting. Thank you to all you experts. It worked for me by simply removing the metal plate, I never even got to the point of trying to short terminal 3... this must mean that I am having a contact to the plate between the batter and the LCD. I am scared to put it back together now, lol. Lets see what happens...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How did you get on Sid.?
I cleaned contact and ground with isopropyl on mine and got a spark but still no go.?
What are my options now - tried to get another spark but nothing..
Not reading in iTunes and no power up..
Thanks..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
OK brilliant people:
Rob I love how detailed your answer was and I tried it with some success. Here is the whole story:
Replaced the screen with success and everything worked fine, until he went to charge it. Then it wouldn't charge.
I took it apart again and got it to connect to my computer. The screen got damaged so I replaced it again.
When I got it back together it was white. I tried the hard reset and after it turned off it wouldn't turn back on again.
I then tried your grounding trick and got it connected again. Again the new screen was white, so I again tried the hard reset. Same results.
It appears that I can get it to connect, but I can't get a picture. Also if I try to rest the device I lose all connectivity and power.
I have looked close and I don't see any obvious signs of damaged cables, etc.
So anyone have a great answer as to how I should proceed now?
Thanks,
Brian
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks Simon Nash.
Your Solution Worked for me.
I really appreciate your help.
Im from Sydney Australia . Let me know if I can help you with anything.
Cheers !!!
LITTLE MASTER'''
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Brian,
i have an ipod that is doing exactly the same thing ! at first dead , now white screen and if i try a hard reset it no longer recognised by computer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do you need to charge it to put it in DFU mode?
Do you need the battery to ground it? Also if you ground it, what does it have to do with a spark.
I am very worried. PLEASE HELP.
Update
My ipod wont charge, turn on, or connect to iTunes
Any ideas
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem with 2 ipod 4th generation devices. After replacing the screens I had nothing (black screen). I tried unplugging and reseating the cables and then the screens would power up with a white screen or still do nothing. Did this several times with no luck. I tried shorting the battery (3.7v pin to ground) and this had no effect. I finally plugged them into a computer to see if itunes recognized them and it did. What I discovered was the software was a verstion 5.x.x and iTunes was telling me I needed to update the software. I updated the software on both devices to 6.1.x and then plugged the screens back in. Both powered up with a white screen and I did a reset (home button and power button for 10 seconds) and both devices powered up with no problem.
Cory
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I had a second one do this to me. Same as the first. What I didn't know is the answer was here all along, but I didn't understand.
DFU mode is the key, but it will wipe the memory off the device.
Here is how to do it. Plug it into computer with iTunes running. Hold sleep button for 3 seconds, don't let go and add home button, hold both for 10 seconds, then let go of sleep and hold home until you get the dialog that the iPod is in recovery mode. Restore and voila.
On the iOS device the difference between recovery mode and DFU mode is that in recovery you see the connect to iTunes logo and in DFU the screen is blank. (This is useless if you have no picture to begin with.) Here is what I didn't know: on the computer in iTunes the two modes look the same. The other thing I didn't know was that getting it into DFU mode will work if it isn't showing up in iTunes already. It even charges without you knowing it is.
My daughter's iPad mini helped me discover all this. It got locked into recovery mode and while I was trying to get it out I discovered DFU mode by accident. Once I discovered that the two look the same in iTunes I got both iPods back from the dead.
The second one I had to do the steps above a couple times before it worked, but persistence won out. I hope my revelations help someone else. I'm sure some of you are going, duh, but I was educated and am better for it now.
Thanks to all the posts above, they all helped me piece the solution together in my slow brain.
Mary,
Try my steps. One of the two wasn't showing up in iTunes, but it did in DFU mode. If it doesn't work the first time try again. I had to do it several times to get it to connect. Also, I read somewhere that even the smallest tear in a cable can make a different, did you check them all?
Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well,
I have tried everything on here to no avail! I was replacing the screen (owner tried but ripped volume cable) I soldered a new one in. I'm getting continuity through it and the battery is registering a 3.5v. I shorted it out and got a small spark but I can't get my PC to recognize it so all I have is a paper weight help! I have photos but don't know how to put them up here!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm having the same problem as most, I just replaced the screen although it had broken a long time ago 1-2 years maybe. I wonder if that has something to do with it. Anyway it won't turn on, won't charge, won't be recognized in iTunes and noting happens when I attempt to put it in DFU mode. I tried grounding the battery terminal and nothing happened. I think that all cables are attached and nothing is loose. Any suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Got an email from Andrew. Hey man, if the battery has no charge then the grounding thing is not going to work.
you might try it with the cable hooked up. or leave the thing charging for a long time and then try. it has to have current for that to work.
if there is no way to charge it, it;s possible your battery is dead as can be and you need a new one to get the current. see what I mean?
has to have power source to be able to kick it over.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
holy crap! I can't believe that worked! Thank you!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am having the same issue as everyone else. I just replaced the battery. It had a full charge. I plugged the screen up... Still nothing. I shorted it out and got a spark. The screen still did not come on. Now the the merger is showing the same low charge before replaced the battery. Still does not seem to be charging. Also I don't see any ripped cables.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
iPod Touch 4th Generation Blank Screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried to short it and it worked. But it zapped the battery and won't charge or turn on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the power plex is what you tour. it make to power button work. if it tairs you need to send it in to phone doctor and they can fix it. so it is not the cam... wire you tour it was the power plex. it costs $50.00 to fix $25.00 for the part $25.00 for the labor plus shipping and handing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
replaced screen wont turn on short the battery and the screen shows lowest battery then the apple logo the shuts off. Before I shorted it I check and it was 3.1v now it is at .4 still nothing ordered a battery hope that fixes it maybe I don't know I just know I don't have the money to replace the whole thing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So I read EVERYTHING ON HERE nothing worked I tried all the battery stuff and the reset stuff nothing worked it either made the screen turn white then it made my screen turn black, the white not even showing up SO I TRIED ONE OF THE THINGS IT SAYS ON HERE TO PLUG IT IN TO ITUNES .IT DIDN'T WORK BECAUSE MY IPOD DIDN'T SHOW UP ON ITUNES SO THE NEXT DAY I DID THE SAME THING EXCEPT TRIED DFU MODE WHILE ON ITUNES IT TAKES A COUPLE TRIES BUT IT FINALLY FOUND THE IPOD AND IT IS RESOTRING IT AND ALL IS WELL
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi I did a screen replacement for the ipod touch and when I went to turn it on it wouldnt power on and get recognized by itunes. It was working fine before I did the replacement everything was working.
I have done:
Grounded the battery terminal
recovery mode multiple times
dfu mode multiple times
tried plugging it into ac adapter will not power on
I have read multiple forums on this situation and it sill is just a brick please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
whoever the OP is - you are a fecking legend!! :-D
To be honest i never thought the battery terminal to earth jumper would work, but touched them together for a millisecond, then pressed the power button and it booted!
Very happy - Thanks buddy :-)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Will this technique work for 2nd generation iPods?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
test
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Black Screen/No Response after screen replacement Fix:
I've read almost every post on this issue because I had the same thing with my ipod 4 until about 5 minutes ago. Here's what I did:
* I was grounded working on aluminum foil
If you're 100% sure you didnt tear any cables etc, and everything is connected correctly, before you 3m tape or adhesive anything:
1. I tried the ground fix of touching one end of a wire to the home button bracket and another to the 3 solder point for the battery. I got a small spark. That insured me i didnt short anything out.
2. connect the ipod to itunes with sync cable. while still plugged in disconnect the screen cable with the plastic tool from my repair kit. Itunes recognized my ipod. (you may need to hit the power button) I plugged the screen cable back in to board, and itunes stated: your ipod is in restore mode, do you want to restore the firmware. I chose yes. Itunes restored the firmware and updated my ipod. after the process was done, my ipod was working again.
さんによる
コメントを追加
I replaced the battery today on a pod 4, and I have done about 30 of them, except this time, the unit won't charge ?
The pod starts up, works fine, but won't take a charge.
When I plug to pod into a doc station, it shuts down the doc station ?
Any help would be appreciated.
Repairs@iscreens-mackay.com
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
As an update, I decided to go back and resolder the connectors again, with some more flux, and it seemed to fix the issue.
さんによる
コメントを追加
Hi all I've been reading this with much interest as I just replaced the screen on my ipod touch and got white screen.
I reset it by pressing sleep and hold and it went off and completely died. Would not charge power up or be recognised by itunes.
So followed Robs advice and shorted battery, yay ipod now powers up to white screen.
Connected to itunes and pressed power button for 3 seconds then while pressing power pressed home as well for 10 seconds and got restore message on itunes.
Now downloading restore software so hopefully this will resolve all issues.
This was the most useful thread I have come across for resolving this issue so massive thanks Rob.
Will update tomorrow once ipod restored and hopefully working again fingers crossed.
Andy D
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi everybody.
I had the same problem. Replaced my broken screen, wanted to turn on the Ipod, unfortunately nothing happened. I read lot of suggestion an experience here and I decided to try the ground trick.
I afred of this (maybe the logic board will burn out) and I only put out the middle metal plate (the large, between the LCD and the Battery) Turn on the Ipod in this position, and shows connect to charge.
I plugged it to the PC, and now it's charging and looks working. ;)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I replaced the screen/digitzer on my son's 4th gen Ipod, and nothing happened when I turned it on, so I checked all the connections, and nothing happened.
Today, I tried the battery ground, and the screen came on. Wahoo!
BUT....the touch screen is not responding to touch. I used the voice commands and can play music or use facetime.
What else can I try? The orange ribbon in the upper left corner (that is sitting on a plastic-like pad) was near the site of screen break, and there is some remaining black stickiness in that area. I did remove all the shards and pieces. Should I try to remove this residue? Is this a sensitive area?
Any other way to know if I just got a bad digitizer or if I damaged the Ipod itself?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My iPod won't charge while on and won't connect to computer/iTunes
Can someone help me?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There are many solutions, read it above.
さんによる
コメントを追加
OK so my neighbor replaced my screen on my ipod. The only thing wrong with it then was the home button was touchy. It was working fine for the first two days and then after i came home I put it in my pocket. When i later got it out the screen was black and it no longer connects to itunes. Ive tryed reseting it, but nothing happened. Then i tryed to restart it but again non of the buttons work and i cant do it from itunes because its not recognized. I dont know what to do or how to fix it, please help!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just to help you all out, I confirmed that a latest update fixes compatibility on new replacement screens. I was having issues as well with black screen lightly flickering but not powering up, however the oem cracked screen I took off was working. I had 3 screens tested on another ipod touch with ios 6 and all worked, but not with the one that was on ios 5. I updated ipod touch with the cracked oem screen on iTunes to ios 6.1.6 and tested the screens and all worked fine now. The black flickering I can confirm is a ios compatibility with replacement screens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The shortening of the terminals worked thanks guys really appreciated
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Otherwise, what can I do if I get white screen? I tried the shortening trick, its worked but whenever I put the middle frame back the Ipod wont power up. Now its power on but with White screen. The other functions works great. Is it possible the LCD slot damaged on the motherboard or the LCD cable?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I was working on screen replacement and accidentally disconnected the data cable while the new screen was powered 'on' and after reconnecting had the black screen problem everyone above has noted.....the battery shorting procedure fixed the problem (TWICE I did the same thing TWICE) Great FIx ! THANX
さんによる
コメントを追加
I followed all the steps. The iPod turned on but the touch screen doesn't work. Im really mad
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've learned to fix the IPod maybe waste your time. Most of the situations you need lucky to get your pod back to life, it doesn't matter you try with new replacement parts.. Someone wrote above its a woodo and I completely agree :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I recently replaced LCD and digitizer screen on Ipod 4th generation. I got it to power up before I put the heat plate on to make sure it was going to work. I went back to put heat plate on and closed it up and got nothing after that. I thought maybe the batter needed to charge so I plugged it in and got the battery charge sound, but no picture. Itunes does not recognize it when I plug it into computer. Another question I have as well is that there is a white mesh sponge (very little) that you're supposed to transfer from the old screen to the new one that adheses to the bottom of one of the cables. Is this a vital step or can it be left out???
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I use to leave that mesh part off of the new screens, but I read somewhere that leaving it off contributed to this problem. Since then I have started to transfer it to the new part. I have not had a repeat of the issue since I started to do that. Not sure that is an answer to your question, but it's what has worked for me.
さんによる
Thank you Brian.
さんによる
コメントを追加
I know this thread is old but Im having a black screen afterLCD and battery change.
Put ipod in recovery anf itunes see's it but testore fails with error code 1600.
I think the LCD connector came off whilst iPod was on! I dontvthink its a backlight issue as screen totally black. Prior to putting screen down all was good during test. It was only have lifting screen to finalise things that screen connector popped off.
Please help. That LCD connector is so fiddly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
thank you so much, after trying it many times, it worked out well. Couple of times i tried grounding it on the side metal body of the ipod but it didnt work. then I came across Rob's picture tutorial tried grounding it on the metal as shown in the pic for 30 seconds then plugged it in and it worked... thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
IMADV8 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 55
今までの合計 105,523
