メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
Connecting as external monitor to windows laptop
So. ill try to make this as clear as possible. I have a imac a1312, with set password, I cant get into it, but i dont actually need , because i just want to use it as external monitor. I've tried to connect it to my windows desktop pc with mini displayport>displaypor cable, and it works without issues. i just connect it, and imac shows image right away. Now my needs changed a little of bit, and i want to connect imac as external monitor to windows laptop (win10 or win11) , i have several of them. So i bought Mini displayport>HDMI cable (because all my laptops doesnt have displayport slot), and once i connect cable to laptop. nothing. FN F2 or other combinations doesnt work. i tried same cable with my desktop, and it doesnt work too. I tried tons of adapters ,still no success. i tried all my cables to another devices , just to be sure all of them is working. so it seems, imac accepts only mini dp>dp cable? hard to believe that any tips or suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Apple assumed people would use a Mac not a windows system. Even still a windows system which offered a miniDP could leverage it. The problem is an HDMI or other interface don’t carry the needed signals to do it.
Here’s some useful info:
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tomas Vonsavicius just turn your iMac into an external monitor. Use something like this guide How to turn a iMac Intel into an External Monitor - iFixit Repair Guide Even this answer SOLVED: How to turn an iMac 27 " 2010 Display into an external Monitor - iMac Intel 27" EMC 2390 - iFixit will help you out with it. All you essentially need will be LED driver boards and a power board like this Not very complicated but rewarding when done.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tomas Vonsavicius さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 64
