メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Problems with jack input on MacBook Pro 2015 15"
When i plug apple Earpods into the jack input of my MacBook they work only as headphones, mic doesn't work! I've tested them with another MacBook - they work, everything is ok. Why there is this problem and how i can try to solve it? Thanks!
Best, Marco
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Mmm… as long as the headphone plug and cable are not damaged, then the issue is within the logic board socket assembly. Apple uses its own design so you’ll need to find a junker with a good socket. Replacing the logic board is the very last option.
As to what went wrong there are two switches within the socket which the signals from the internal speaker/mic to the external ones. Here’s a deeper write up Understanding Audio Jack Switches and Schematics.
Sometimes you can use a toothpick to re-align the blades if twisted, I haven’t found this works in this series but worth a try
I think you might want to find a USB DAC unit which will by-pass the socket issue. Or just use a Bluetooth headphones/buds.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Giovanni Boccamazzo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
