How do I remove corroded batteries?
The batteries are very corroded. So much that I have not been able to unscrew the end piece at the led end of the body.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This answer should solve your problem:
このアンサーは役に立ちましたか?
If they are very dirty as you say, I’d suggest using some using some sort of stick of some sort to peel out the AA batteries depending on which type of battery if they are normal batteries, I suggest you use rubber gloves do not touch the battery corrosion because it can make very bad irritation happen to the body and I suggest after you remove the batteries try and use IPA alcohol I am on the contact pads with an earbud cleaner
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 34
今までの合計 2,760
1件のコメント
Same problem here. Can’t get the end off even with a wrench.
Kat さんによる
