Screen cracked inside, can it be cleaned, as there is black fluid?
Is it possible to clean the screen from the inside to get rid of the black fluid? Or will this just keep coming back?
The fluid is the Liquid Crystal material that makes the LCD display work
Bottom line the display is damaged and needs to be replaced!
Here’s the needed part MacBook 12" Retina (Early 2015-2017) Display Assembly and here’s the guide to put it in Retina MacBook2015ディスプレイアセンブリの交換
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 21
