メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus Nord N200 5Gは、OnePlusのエントリーモデルスマートフォンです。6.49インチ(1080 x 2400)の画面、90Hzのリフレッシュレート、64 GBの内部ストレージ(最大256 GBまで拡張可能)、4 GBのRAMを搭載しています。
How do I replace just the front glass?
Out of all the videos I've seen, most just get a full lcd replacement. I don't want to replace that, I just want to replace the screen glass.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi Lily,
The problem here is that the LCD and front glass are bonded together with a glue called OCA, or Optically Clear Adhesive. It generally requires specialized tools, equipment and experience to separate them successfully, and then rebond the new glass to the old LCD. In almost all cases it's not worth the time and effort it takes to do that; in order to make sure you don't get bubbles in the glue you need to cure it in a vacuum chamber, which most of us don't have at home.
Since the replacement display sells for under $25 USD on AliExpress, it's really not worth your time to mess with separating the glass, cleaning the LCD, ordering the correct OCA and then trying to get it reglued without bubbles. I strongly recommend you just bite the bullet and replace the whole thing.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Mi pantalla está roto
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
For those of us who don't speak Spanish, Google says this means:
My screen is broken
さんによる
Hi Yanick,
Assuming you're coming here for help in repairing your screen, even though iFixit doesn't have any information on your phone, that doesn't mean we can't be of assistance.
This same repair has been addressed on here previously; see the following post for information on replacement parts and instructions.
Need a new screen
さんによる
コメントを追加
回答を追加する
Lily Mung さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 1,115
