メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Pavilion 15-cc561stは、HP Pavilion 15-cc500シリーズのノートパソコンです。2017年7月に発売され、製品番号は1KU29UAです。
Why is my disk making noices?
My disk makes a noise every 5-8 seconds, additionally the computer has become slower. I have tried cleaning the disk and nothing has changed. Do I need a new disk?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Are you sure it is not the cooling fan? Otherwise your drive is likely dying. Immediately back up any important data.
Oh and upgrade to an SSD drive for a faster computer.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have switched to a sdd and the noice kept going. Any alternatives you would recommend checking out
さんによる
コメントを追加
If your HDD is making noise, it is most likely damaged in some way and needs to be swapped out immediately. You most likely cannot backup any files from a corrupt HDD, but if you manage to, that's nice. However, if it's too damaged you can't simply replace or fix any parts of the HDD. You will have to buy a new one.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I have switched to a sdd and the noice kept going. Any alternatives you would recommend checking out.
さんによる
@Isaias Savoca
What is the make and model number of the laptop?
If the HDD was replaced with an SSD the only things left that can make a sound is the fan, the CD drive (if CD inserted or maybe even if not) or if you have audio playing through the speakers, unless your model laptop has two storage drives i.e. SSD and HDD of course
さんによる
The model is a Hp Pavilion 15-cc6xx. It doesn't have a cd drive. the noice comes in two types it either comes and goes every 5-7 seconds or at times the noice is consistent for a entire minute and then stops for another. Checked the fan and it looked fine to my opinion(noob)
さんによる
@Isaias Savoca
Can you isolate where the noise is coming from?
Have you tried muting the speakers to see if the noise emanates from them?
Since you have replaced the HDD with an SSD, the only moving part is the fan so unless it is a "ticking" type noise as sometimes happens with hot components or a whining noise which could be from a coil in the power circuit there's nothing else.
Post a video which has audio so it can be heard on ifixit
Here's how iFixitでの質問に画像を追加する方法.
Adding video is the same as images as you are just uploading the video file.
さんによる
コメントを追加
回答を追加する
Isaias Savoca さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 334
