Tumble Dryer not starting
My Hotpoint Tumble dryer stopped working. It showes E2 on the display
Robatzchi Mirabela we will need to know the exact model number for your dryer. E2 for your dryer's manufacturer is most commonly caused by a thermistor failure. It gets triggered when the exhaust air temperature is either below or above a certain setpoint. Besides the model number, it will also help if you can let us know what you have tried,checked.
You can checked the thermistor with an ohmmeter, A value of less than 500ohms will indicate that it is defective. Besides the thermistor, check the heating element for continuity and check your dryers airflow. Make sure there is no obstruction on the air outlet.
このアンサーは役に立ちましたか?
Here's what I found:
he E02 error code can occur when the filters are dirty or blocked. SOLUTIONS WASH OR CHANGE THE FILTERS. Remove the filter cartridge from the filter housing. Using luke warm water, run the filter cartridge under the water until it runs clear.
Hope this helps.
Also try this:
Most dryers will have a reset button on the control panel or behind the machine. Make sure your dryer is cool and not immediately after a cycle before your press reset.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 1,098
1件のコメント
This question was migrated from https://meta.ifixit.com/Answers.
iRobot さんによる
