メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dyson AM10 加湿器の修理および分解情報。
What does a Piezo do?
My AM10 has stopped misting, doesn't draw any water from the tank.
I am trying to troubleshoot it.
First stop is something called a PIezo, which is accessed from a panel on the bottom of the base unit.
my looks to be in poor condition but I don't know if it is the source of the problem. in fact I don't even know what it does.
it appears to have a watertight seal. so it must be sitting at the bottom of the water tray.
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
最も参考になった回答
@pjstock, A piezo is basically a “speaker” or more commonly known as a buzzer.
I say “speaker” because because it’s not playing sounds as a speaker, it’s only really capable of producing tones in given ranges.
You can Google “piezo buzzer” if you want to read and understand more about it :)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Google it. Loads of different types.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi. I have the same issue with my am10. Have you found a solution?
Thanks! I’d appreciate it!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
change it will help. I also have the same problem and find it in amazon https://www.amazon.com/dp/B0BWN3BZR8
さんによる
コメントを追加
I think in this device working the piezo element not like speaker but like object size detector. Same like in dyson vacuum cleaner. Small pieces hitting the piezo, thats generate a very small current, from this currend is calculated how many and how big pieces was catched.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same issue . No mist anymore . I changed the piezo but it did not help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
peter stock さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 37
今までの合計 1,649
