メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ロジクールのMX Ergoワイヤレスエルゴノミックマウス向け修理ガイド、分解手順、およびトラブルシューティング情報。モデル番号M-R0065または部品番号910-005177で識別されます。
Trouble with left click button
Hello, I am having trouble with left click button, especially when dragging windows. I think similar problem exists in other trackball mice as well. Hoping to find a DIY solution.
Regards,
Sachin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Hello Sachin,
I didn't myself have had any trouble with the Ergo's switches, but I did with other mice. The solution to your problem would suggest a problem with the switches. Since I don't have specific experience with the Ergo switches, I would suggest you search on iFixit "switch Logitech". I noticed there are some fora discussions and also instructions on how to replace the switch (if it comes to that), which parts to use etc.
I'm sorry I can't give you a straight answer.
Good luck!
Eiti
* If you do find a solution, please post it here. I'm sure I (and others) will eventually get to the point where my Ergo will need some work on the switches. Even if you don't want to go through the trouble of taking pictures and writing a complete instruction, just describing your solution as an answer here would be very helpful.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sachin さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 10
過去 30 日: 20
今までの合計 1,144
