メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月に発売された、ストレージ容量32GBまたは128GBのApple iPad(第7世代)Wi-Fiモデルの修理ガイド、分解、およびトラブルシューティング情報です。型番はA2197。
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
@willjoe it’s not a touch issue it’s an image issue.
さんによる 共有
コメントを追加
回答を追加する
Oliver Byrne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 568
