Buzzing/Rattling when French doors are open
I have an LG LFX25991ST French Door Fridge. There is a loud buzz/rattle that started and stops when I open either door. Is there an inexpensive fix?
Hi @cjndj1,
What is the full model number of the refrigerator?
Does it rattle all the time when the compressor motor is running but stop when you open either door?
If so it sounds like a problem with the evaporator fan.
このアンサーは役に立ちましたか?
It’s Model # LG LFX25991ST/05 Yes it stopped when I closed either door. I just changed the the air filter and water filter and it stopped. Hoping that was the problem but if there’s something else we need to do pls advice and thank you!
Time will tell, but if it has stopped most probably that was it.
Thank you for your quick response. I will type back if it starts up again
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 269
