How to change the battery
My battery nearly died and i need to change it
Ahmed Hosam easy enough. Use something like this video the get it replaced. While you are doing it, take lots of pictures and create a guide for the rest of us. That way you are helping another person with the same issue. It is not very complicated Create a new Guide - iFixit
このアンサーは役に立ちましたか?
If you prefer a step-by-step written guide like those on iFixit, the French site SOSav has what you're looking for.
https://www.sosav.com/guides/mobiles/sam...
Note that their auto-translation turns 'battery' into 'drums' and 'flex cable' into 'tablecloths', but other than those idiosyncrasies, it's pretty well done.
Excelente, gracias por las guias, me sirvio mucho 👍👍👍
Just as an update here since I can't edit comments, it appears SOSav has discontinued their English language .com site, so the link above no longer works. However all the original material is still available on their French site sosav.fr. Here's a usable link for that same guide.
My phone's battery always goes off when it's at 30%,please help me out.
このアンサーは役に立ちましたか?
Hi Andrews,
That's most likely an indication that the battery is worn out and needs to be replaced. That's something you can do yourself with the guide I mentioned previously, assuming we're still talking about a Samsung Galaxy A30s.
https://www.sosav.fr/guides/mobiles/sams...
If you need any advice or assistance in the process let us know and we'll be glad to do what we can to help.
If I talk about the smart phone of this new generation. It's going to be tough to change the battery in Samsung by yourself. You have to visit a repair shop to change your mobile's battery.
このアンサーは役に立ちましたか?
@sonamsharm73084 even so it is not as easy as it was 15 years ago, the batteries can still be replaced. There are plenty of instructions on how tondo it at so many different places. Just check the guides on iFixit or anywhere online.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 1,689
6 件のコメント
Yes i need change my better
Sofoniyas Adey さんによる
Fast phone charge very fast charge battery is .outlying 2 days charge
Shivansh raj Chauhan さんによる
My battery is very slow charging
Vishnu Vardhan さんによる
My battery drains very quick
Abiy さんによる
@abiy54946 As batteries get old they lose the ability to hold a full charge. If your battery is aged, it may only be holding a fraction of the charge it's supposed to and thus the small amount it does get is used up quickly.
The solution for this is usually to replace the battery. See the instructions in the Most Helpful Answer below.
Jerry Wheeler さんによる
1以上のコメントを表示
