メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
メガドライブ(北米地域での販売名はGENESIS)は、現在までにセガで最も成功したビデオゲーム機です。
Model 1 board, does this look normal?
I took apart My model 1 to clean it up etc and while looking around I came across a spot where it looks like a trace was damaged. I’ll post pics of the top and bottom of the board so you can see. The spot in question is circled in red.
画像
画像
Update (12/09/2022)
So I somehow found a post on sega-16 about a genesis with a resistor on the bottom with a cut trace, exactly like mine. I'm starting to think this was just some factory "fix" or "repair" rather than a mod. Second post has a working image link which shows the same kind of resistor on the same spot with the trace cut.
https://www.sega-16.com/forum/showthread...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
さんによる
コメントを追加
4件の回答
ベストアンサー
Kevin F, That resistor just outside your circle is NOT factory. I’ve attached an image of that area on another Genesis Model 1 board.
There were a lot of mods done to these over the years, and this is one of them. Unfortunately, there’s really only one way to figure out which mod this is, and that’s to ask someone heavily into Sega modding. I’m not one of those, so my solution would be to traverse the darkest and weirdest corners of the modding interwebs
画像
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
That’s interesting. The board generally works fine but I experience a weird issue with some Sega CD games and freezing (Lunar and Vay) when my 32x is attached. However I have a second genesis that doesn’t freeze with those sega cd games.
I wonder what would happen if I removed that resister and fixed the trace?
さんによる
Yes, the resistor is factory. All my boards have them.
If you are referring to the THT resistor that's just bolted on there. The cut trace is also normal
さんによる
コメントを追加
最も参考になった回答
hard to say, you could check continuity from 1 end of the trace to the other with a multimeter. thats the easiest way to test, other than that scrape back the top coating to see if the copper is broken
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi Kevin,
To be honest, that looks like a rework of some kind. No way to tell if it was done at the factory or not, but it's obvious a resistor has been removed and one end rerouted to a different connection. They should have cleaned up the flux afterward and it's not the best rework job I've seen, but it was most likely a fix for an issue discovered during testing. Assuming they had a bunch of boards already manufactured that required a fairly simple change, they elected to do this little kludge rather than throwing away a large batch of circuit boards until they could get the PCB revised.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I’m wondering if I remove the resistor and try to fix the trace of the console would still work.
The console does work as is but I experience a weird issue with some Sega CD games and freezing (Lunar and Vay) only when my 32x is attached. However I have a second genesis that doesn’t freeze with those sega cd games While the 32x is attached.
さんによる
@Kevin F That's a tough call. Without knowing what the purpose of that fix is, there's no way of telling what will happen if you undo it. As @geirandersen suggested, I personally would head down a few internet rabbit holes in search of what that modification is all about first.
さんによる
Yeah not a bad idea, I just don't know how to even go about finding info about this particular "repair"/"fix".
さんによる
コメントを追加
That’s not factory, soldering is crap. Looks like someone has repaired it at some point. If it works ok I wouldn’t touch it.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yeah the soldering is crap for sure. And the Genesis does work for the most part but I experience a weird issue with some Sega CD games and freezing (Lunar and Vay) when my 32x is attached. However I have a second genesis that doesn’t freeze with those sega cd games with the same setup.
さんによる
@Kevin F only one way to find out
さんによる
コメントを追加
回答を追加する
Kevin F さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 56
今までの合計 1,959
