メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Meeting Owl Proは、共同会議用の360度カメラ、マイク、スピーカーシステムです。
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
1 件の回答
最も参考になった回答
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
caroline work さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 64
今までの合計 1,920
