メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi Redmi Note 9は、2020年4月に発売されたXiaomi製のミドルレンジスマートフォンです。6.53インチのIPS液晶ディスプレイ、48MPのメインカメラ、背面指紋センサー、5020mAhのバッテリーを搭載し、MediaTek Helio G85で動作します。
Phone drop in water
Yesterday my phone drop in water it was working fine but the flashlight was on and not turning off so i power off the phone but flashlight is still on and not turning off and now my phone is not turning on but flashlight is on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Phone drop water not on my phone
さんによる
コメントを追加
2件の回答
最も参考になった回答
saleemkhanx001, The first thing to do now, is to stop trying to turn it on and DO NOT connect a charger.
You’ll have to open uptempo phone and remove the parts on the inside, for best results. Inspect the boards closely for corrosion and damage, you’ll need good lighting and possibly a magnifying glass. Use some distilled water and gently use a brush (fex a toothbrush) and clean the boards and case. Apply gentle pressure, but do not overdo it.
Once you gone over it with distilled water, do the same thing with >99% isopropyl alcohol. The IPA displaces the water, and IPA evaporates in seconds to a couple of minutes. Once you’ve cleaned everything with IPA and have let it dry off, make sure once more that there is no damage or corrosion present on the boards.
Connect the screen and battery again and check if it will boot. I prefer to test the devices for 100% functionality before I close it back up. If you’re lucky and there hasn’t been any bad damage, your phone should start again, but remember: even one single drop of water in the wrong place can be truly destructive for a phone!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My phone had repaired but still facing problems related touch not working properly and front camera, rear flas light not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
saleemkhanx001 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 549
