メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第2世代Apple Silicon(M2チップ)搭載、13.3インチRetinaディスプレイ搭載のMacbook Pro 13インチ用の修理ガイドと説明書です。モデルA2338です。2022年7月15日、WWDC2022でMacbook Air M2とともに初公開。
Is it possible to replace the display?
The title says it all. Is it possible to repair the display?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Yes, but it will require either letting Apple fix it or you can do it yourself but! Apple now serializes the display to your logic board so you must use their part as you need access to their calibration tool which will only work with the display they shipped and is a one time access as part of the Apple Self Repair program. Sadly, the newer MacBook M2 systems are not offered yet and this program is only in the states.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you for your answer. It looks like I can't repair it myself since I don't know the calibration tool and as you said it's not in the Apple Self-Repair Program.
さんによる
@Anon User - Sorry Apple is a bit slow on its service options both for the newer M2 systems as well as other countries. If you are set, don’t forget to accept the answer - Thanks!
さんによる
コメントを追加
A replacement display would work just fine. But if you ever take the repaired machine to apple, they would say they cannot “authenticate” the display; so, depending on the genius, they may allow other repairs at their discretion. Important to note that each display may have different color settings because of their batch but that has nothing to do with serialization.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anon User さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 17
今までの合計 1,030
