メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo GameCubeは、任天堂の4番目の家庭用ゲームコンソールです。修理は簡単で、一般的なツールだけで行えます。
drive won't spin- won't read disk
bout ready to drop kick it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
bill give us a bit more information. Did this just start or did anything happen recently that brought this on? The more information that you post the easier it will be to answer. BTW if the drive does not spin, it won't read it.
さんによる 共有
Please keep in mind that any DIY data recovery attempt can cause permanent data loss. If you’re in need of a reliable data recovery service I’d strongly recommend Ultra Data Recovery. We do the same jobs as the “big corporations” (such as heads and platters replacement if the drive has mechanical damage), but actually affordable: www.ultradatarecovery.com
Free diagnostic, you'll know what could be recovered.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
first of all make sure that you disk is really not spinning. When you first power up the game cube listen closely if you can hear the drive spin. It will stop when you open it. If you absolutely do not hear anything and are 100% certain that your drive is not spinning, it is possible that your drive motor is burnt out. this would require either a new optical drive or a repair of the drive motor. Check this guide for a repair of the assembly as well as the replacement. There is also a possibility that your laser is either dead or not having enough power. Since it can't see a disk, the optical drive won't start up. Try to clean the lens with isopropyl alcohol. You can adjust some of the laser's power by adjusting the pod on the circuit board of the optical drive, check this guide for instructions on that. As you can see there are plenty of things you can try before you drop kick it :-)
Nintendo GameCubeの画像
ガイド
光学レーザーレンズの出力調整
難易度:
中レベル
30 minutes
Nintendo GameCube 光学ドライブアセンブリの画像
ガイド
Nintendo GameCube 光学ドライブアセンブリの交換
難易度:
中レベル
30 minutes
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
+ They should go for the touchdown instead of the field goal, lol.
さんによる 共有
コメントを追加
My game cube will not spin, but it also doesn't even display the game cube start up menu, but it has power and inputs work. Suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bill さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 23
過去 30 日: 122
今までの合計 70,733
