メインコンテンツにスキップ
2015 Retina MacBook Airの修理情報とガイド。モデル番号はA1534
281回答 すべてを表示
keyboard not working properly after reassembly
Hello dears,
I was working on a mac that client spilled water on the keyboard ,opened it and checked if there's any leak inside.
disconnected the trackpad cable and battery, then reassembled again with no issues.
Now when booting it shows me "Macintosh disk" i need to select it everytime and when reaching the user passord some of the keys don't type (only make sounds).
After resetting SMC or NVRAM it works correctly but i need to do it everytime.
I managed the startup disk and selected it. it worked for 2 days and now same issue again.
Please if anyone that has the fix and can help it would so much apreciated.
Update (11/28/2022)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Let’s check the battery install this app CoconutBattery. Take a snapshot of the apps main window while on the charger and post it here for us to see.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for replying could't post the photos i'm new in the site
But what is shown on Coconutbattery main window when on charger
Macbook (retina 12-inch Early 2015)
Model: Macbook8,1
Current charge 2067mAh
Full charge Capacity 5297 mAh
Design capacity 5297 mAh
Cycle count 957
MacOs Battery Status Cehck Battery
Battery temperature 28 C
charging with: 0.49 watts when first plugged then now 16.6watts & 17.37 watts
If you can help would be awesome thank you
さんによる
@edddybk - Well your batteries cycles are inches from the expected life of 1000 so you do need a new battery and the battery is even telling us that.
Here’s the needed part MacBook 12" Retina (Early 2015) Battery and the guide to put it in Retina MacBook 2015 バッテリー の交換
It maybe best to find someone local who has the skills and experience as this is a bit tricky!
さんによる
@danj Thank you for your time i appreciate it so much!
Will do so
さんによる
コメントを追加
回答を追加する
Eddy BK さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 68
