メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Oneplus Nordはミッドレンジのスマートフォンで、2020年に発売されました。6.44インチ90Hz Fluid AMOLED、8/12 GB RAMのSnapdragon 765G、128/256GBストレージを搭載しています。4つのリアカメラと2つのフロントカメラが付いています.
How to clean dust in front camera?
Hey there, I've knocked around my OnePlus Nord phone a few times and I have had the front screen pop out just a bit from the corner a couple of times but now I can see dust underneath my screen and I'm wondering whether it would be safe for me to just open the front screen, get some compressed air or a microfibre cloth and just try to clean it off. I'm pretty sure I'm out of warranty on my phone too. If I'm going to do that, what tools do you think I would need and what tips should I take before doing it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
"front screen pops out just a bit from the corner" Can you provide pictures of it in that state? Or can you carefully lift the screen with a toothpick and take pictures of the dust area?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi
To clean the front cameras you need to take the screen off first
Here’s a guide for that
OnePlus Nord スクリーンの交換
As for cleaning the cameras them selfs I recommend using a cotton bud/Qtip with some isopropyl alcohol
When cleaning make sure to be careful because cameras are extremely delicate
For this repair you will need basic screwdrivers,suction cups and pry tools
Ifixit sells a small tool kit that has these sorts of things in it
Here’s a link to it
Essential Electronics Toolkit
Also once you have taken it apart you will need to adhere the screen back on using some adhesive tape
Here’s some ifixit sells
Tesa 61395 Tape
Hopefully this helps
Any questions please ask
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair.の画像
製品
$29.95
Custom cut rolls of Tesa 61395 double-sided tape for repair.の画像
製品
Tesa 61395 Tape
$8.95
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
thanks! will try this out and hope it works.
さんによる
@aj_clark
Good luck:-)
さんによる
Very nice response. I even learned about the Tesa Tape. Will have to get some.
さんによる
@bessemerjohn
Tesa tape is the best stuff(in my opinion)
I like it because it’s double sided and very thin:-)
さんによる
コメントを追加
回答を追加する
Adam JC さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 37
今までの合計 2,164
