メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron 5559は、2015年に発売された15インチのDell製ノートパソコンです。修理ガイド、トラブルシューティング、その他の情報を確認できます。
Can I replace intel board with amd board?
Dell 5559 i5 6-Gen board is dead.
Can I replace intel i5 6-Gen board with any amd board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Highly unlikely if you want to fit it in your current laptop case, as it seems this model was equipped with Intel CPUs only; and even if you found a somewhat compatible replacement board, it would still require a lot of work.
Limited repairability/upgradeability is a well-known issue with portable devices, hopefully things are gonna change for the better in the near future; some progress was made, as a matter of fact you could have easily swapped your faulty motherboard with a new one if you had this laptop.
That said, if you don't mind getting your hands dirty, and refuse to take a risk and look for a used working Intel board, you could still recycle all the other components, there are many fascinating projects worth looking at: you could build an Arm based computer, or an AIO-like PC you could use as secondary screen, you could even try to build a tablet out of ur old machine; HDD and ODD can be repurposed too.
Hope this helps, feel free to let us how you fixed it
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.の画像
製品
2.5" Hard Drive Enclosure with USB 3.0 Cable
$14.99
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Masroor Amir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 349
